Vst configuration files
skraninger
What kind of info's are you looking for ?
these files can be read with a basic text editor if needed
they are created when you scan your plugins folder, then Usine know which ones are ok, some can be corrupted or create errors and so...
skraninger
I was just wondering if the content of the files had any function. One of the Vsts I am using complains of a parameter problem (but still works).
Users browsing this forum: No registered users and 163 guests
