conductor and grids
noise2sine
Unread post by noise2sine » 13 Aug 2007, 22:27
hello,
I would like to know if it 's normal that in my sampler i'm using the preset manager and the conductor doesn't keep the settings i have saved with preset(loop position,preset numbers)???
then, i would like to know if it will possible to block and scroll up and down the grids scenes display beacause when i'm using 16 scenes, the modules are quite small and i'm loosing space and i don't need to see all the 16 scene because they are organised with the conductor?
thank you.
Unread post by bsork » 13 Aug 2007, 23:04
The preset manager as such isn't stored by the conductor, so you'll have to connect something to the num inlet that is; eg a fader, combo or list.
It can be somewhat confusing that the preset manager isn't stored, but it does give you the option of recalling presets and scenes independently if you want.
About your other question, I'm not sure I understand what you mean. Do you use a large number of grid lines? If so, I don't think it's possible to scroll the visible lines. I have a tip though to make the patches take less screen space: You can "shrink" a lot of the bigger interface elements like the WaveDisplay, the XY, Lines etc by open them as a window, reduce the size and put them back into the control panel. Also remember that controls that you don't need to see because they for instance are controlled by MIDI can be invisible.
noise2sine
Unread post by noise2sine » 14 Aug 2007, 21:59
thanks a lot for your quick answers!!! i will try that...
Usine is like a diamond...
