VST Randomizer
sephult
Unread post by sephult » 07 Aug 2015, 21:05
Hello Everyone!
Just added: VST Randomizer
This addon provides interesting and new possibilities to create patches and sounds for VST synthesizers or audio effect plugins.
This subpatch is used by adding it to a current VST patch.
Only 3 connections are needed to utilize, the parameter array loop, and the parameter names.
Once these are connected, press the reset button...then start adding parameters and press the randomize button. Also select the individual parameters on the right side and adjust the range fader below to limit the randomization.
This add-on does have some quirks, however is currently stable to randomize multiple parameters. Please provide feedback and I will look into resolving any issues found.
-s
sephult
Unread post by sephult » 19 Aug 2015, 18:25
VST Randomizer has been updated and now is part of the VST Tools.
Individual subpatch now has a cleaner interface, as well as some corrected control placements.
It can also be found in combination with VST DaD (Drag and Drop), under the VST Tools sub patch
Users browsing this forum: No registered users and 120 guests
