Switch List Mode for key learn and midi learn
lalo
Unread post by lalo » 23 Apr 2006, 20:29
Hi senso!
lemme do again compliments for this great soft...
an heaven for the improviser ;)
i was doin' my first steps in usine...
and startin' suggesting some :)
when you have a list or you have to control a VST instrument switch i.e. for change wavefrom for an osc..
would be useful to have a List mode for key learn and midi learn....
imagine to have a synth with an osc with 4 possible waveforms....
pressing the learned key the 1st time select the 2nd waveform...press it the 2nd time and the next waveform is selected....
in other words a kind of "step" control
lalo
Unread post by senso » 24 Apr 2006, 12:53
I?ll will extand the toggle mode (available only for switch) in the remote panel to Faders and Listbox.
For example: each time you press a control or a key it does an incrementation and returns at the beginning when the maximum value is reached.
