Midi chords....
noise2sine
I've suggest recently this one :
http://azertopia.free.fr/Supermidiscripter.html
maybe it can do the job for you , you also have the script of usine of course..
it must be easy to do this with usine, pre enter the chords intervals and make buttons that will trigger the two other when you press a note no? do you play from external keayboard or you want buttons to create chords?
noise2sine
hello, thanks a lot yr attention!!! what i need is a tool for composition, i won't play with external keyboard. Concerning the script i'm not at a level i can built my tools scriptwise. What i need is as many chords type with inversions in all keys and then i'm listenening some guitar improvisation i have recorded (drone) and choose different chords by clicking on the midi chords processor until i find the one that fits according to my ears. So i click again (or different) and the chord is recorded in midi in the piano roll
. it can be good for creating original chords progressions
Thanks for yr help Usiners !
a long time ago I made a small utility called composer.
you enter chords on a grid like D-7 G7 CM7 A7#9 and the soft plays the chords in tempo.
maybe it can help I'll post-it in as soon as possible (next week)
noise2sine
it will be good to try yr Senso program ! and for sure others idea will be welcome !!!
there are various midi chorder vst plugins that can do the job.
some free candidates:
az audio domaj // small+ easy
topza chordworx
ChordSpace // advanced still easy
http://www.chordspace.com/ChordSpaceindex.htm
mucoder hypercyclic // maybe the best arpeggiator around, also does chording
mucoder tonespace // complex chorder
http://www.mucoder.net/hypercyclic/
topza chordworx
noise2sine
thanks nice for the tips nice green frog !!!!
Users browsing this forum: No registered users and 253 guests
