Show big audio master out vu-meters
Unread post by cmodica » 19 Feb 2024, 14:34
Hi all.
Is there a way to show in a patch a big audio master out Vu-meters ?
thank you
Unread post by oli_lab » 19 Feb 2024, 18:10
there's a module called "master vu-meter" for that purpose
Unread post by cmodica » 20 Feb 2024, 11:16
I tried with Audio VuMeter Module but it didn't work as expected.
It is ok with Fader Module instead of Audio VuMeter Module.
Unread post by Gilsornette » 20 Feb 2024, 15:17
Audio VuMeter is expecting an audio signal to its input, that's why it doesn't react correctly.
But I tried to use a "Flow to audio rate" module and it also doesn't work. I thought this module was made for this.
Isn't it its function?
Unread post by Gilsornette » 20 Feb 2024, 18:43
ok, I've understood my mistake... If we use "flow to audio rate " module we need to change Master Vu's scale to linear...
and it works well:-)
Unread post by cmodica » 23 Feb 2024, 16:02
You're right, it works fine with "flow to audio rate " and change Master Vu's scale to linear.
Great, thank you.
Users browsing this forum: No registered users and 110 guests
