Retrieve Section Titles via OSC ?
I saw a "send grid sections info" option in the network settings. Does this allow to retrieve Section Titles and Numbers on an external device via OSC?
if so, how to do it?
If not, is there a way to do this?
Thank you very much.
something like this ?
OK, simple.
Thank you, i will test.
See you.
See you.
hi all.
I ask about it 2 years ago, but i don't remember how to send section title to Touch OSC with HH 5.1.211124 ?
I can manage fader, button, etc. but impossible to find how to send text to touch OSC ?
did you try the OSC-send-text module ?
like that.
For TouchOSC, the default host port is 8000 in Usine
in touchOSC editor, you have to create an OSC message in the text field :
Thank you, it work fine with the OSC-send-text module.
In touch OSC i can configure the Incoming Port and Outcoming Port. But in HH I can only configure one port. So i configure the same port for in and out in touch OSC. Is it OK ?
Thank you ?
Thank you ?
Dans usine, le port ouvert 2002 sert à recevoir les données. Par contre, il faut choisir le port 8000 dans les modules OSC pour envoyer vers touchOsc.
Chaque programme a ses ports d'entrées et de sorties et ils peuvent être changés si besoin
Ok. J’ai compris.
Merci beaucoup.
Merci beaucoup.
Users browsing this forum: No registered users and 110 guests
