Grid - Name elements
Hi all.
I would like to have the possibility to name each element of the grid.
Sometimes in complex grids it's hard to find your way around to make changes.
Exemple in the picture below It is not necessary that this name is displayed on the grid, because it would make the display more cumbersome.
But it could be, for example, in the info related to the element.
Maybe in version 5.
Thank you
Maybe in version 5.
Thank you
Hello guys,
It is probably a good suggestion, but remember you have a special line at the bottom of the grid called info. You can add text here to explain a section.
All the best
All the best
Hello.
Yes it is right and i use it. But it will be a better workflow to name the elements and use the info line for more details.
Imagine i put 5 switches in the same section of the grid. It will be faster to read the name of each other than go to the info line and write : the red one is the reverb, the blue one the sampler, etc.
Have a nice day.
Have a nice day.
Are you aware that the "comment" module can be dropped directly on the grid?
No, i didn’t know that !
It seems so ligical …
It should do the job but it need to add an element in the grid and in the patch.
I test it and it works. It needs to add some elements in my already full grid, but it works.Are you aware that the "comment" module can be dropped directly on the grid?
Users browsing this forum: No registered users and 150 guests
