Run an external program from USINE
/interface control /system /system shell command , is a dedicaced module for that
by sefault its notepad, but you can replace by
c:windowssystem32osk.exe
for windows on screen keyboard for ex
Thanks a lot for replying. That is exactly what I was looking for, however it does work for everything I've tried except for c:windowssystem32osk.exe... weird... I just replaced the osk.exe with a third party on screen keyboard app and it is working fine.
What I need now ia a way to "force" SAVE WORKSPACE AS command (Shift+Ctrl+S) to save workspaces to an specific folder and avoid having to scroll between folders when saving. In other words, a way to indicate the path for the folder the workspaces are going to be saved. I would like not to use applications such as HOTKEYS, that I know this can be done with. If everything can be executad inside USINE or WINDOWS it will be fine. I'm not into scripting, that's why I ask for you help.
you can add a send IML module
patching patch control patch send internal message
then write the message, replacing the path and name by what ya want:
Code: Select all
SET_TARGET_PATCH SENDER_PATCH
SAVE_WORKSPACE "C:TEMPmy_workspace.wkp"or here a script version you can paste to empty script and compile.
then can clic on file_name, navigate once to choose folder and name, then when pressing save will save the current wkp to defined location. once set the location should be saved and recalled on reopening the workspace.
Code: Select all
//GLOBAL VARIABLES AND TPARAMETER DECLARATIONS
var pSave :TParameter;
var pFile_name : TParameter;
var mess : string;
//INIT
PROCEDURE INIT();
BEGIN
pSave:=CreateParam('Save',ptButton);
setIsOutput(pSave,false);
pFile_name:=CreateParam('File_name',ptFileName);
setIsOutput(pFile_name,false);
END;
PROCEDURE CALLBACK(N:INTEGER);
BEGIN
CASE N OF
0:Begin
SendInternalMsg('SET_TARGET_PATCH SENDER_PATH');
mess := 'SAVE_WORKSPACE ' + GetStringValue(pFile_name)+'.wkp';
SendInternalMsg(mess);
End;
End;
END;
/////////////////////////////////////Thanks a lot for your help. Two problems though:
1) I'm using USINE STAGE v5. It does not support SAVE WORKSPACE in IML modules.
2) I have no idea on how to use scripts, how to execute or run them.
All I have achieved is to access the (Shift+Ctrl+S) save workspace command by using a plugin inside USINE, then with the on screen keyboard I can type the name of the workspace to be saved. Again, what I need in a way to define the path for the desired folder where the workspaces are saved or stored. I will be creating and saving multiple workspaces on the fly. I have noticed that USINE v5 remembers the last folder that you're saving to but that's is not enough for me because that path can be easily be lost due to other activity, lets say saving a patch to another folder. So the idea is to make sure i'm directed to the selected folder, where workspaces are stored, every time I execute the Shift+Ctrl+S command.
oh thats v5 mmm yeah my solutions were assuming it was HH.... if iml doesn't handle save wksp, the script won't work either as using iml too. ill try to look whats possible in v5, but v5 is quite old now^^
Sorry for the inconvenience, I should have mentioned it before. HH does not work for me, in despite of that I know it is more advanced and powerful many things have changed from v5 and I have too many patches and workspaces that would be a nightmare to adapt to HH, I have given it a try and ... no way, I rather still using v5, it is working perfectly and fill my needs. Thank you very much for your help.
Users browsing this forum: No registered users and 145 guests
