Do Your Own Wavetable V3
Unread post by oli_lab » 05 Jul 2017, 18:22
New version of DYOWT, more stable and user friendly as ever.
the module can record 2 minutes of audio, make it in a large wavetable that can be played on up to 64 separate outputs.
+ few options as the "constant pitch", morphing between current wave and next one, minimal snippet size...
pre-release will soon be in the addons list with all the up to date modules from my lab !
File uploaded: http://www.sensomusic.com/forums/upload ... OWT_V3.zip
Enjoy !
P.S. there was a small bug and now it is fix (so I think)
sephult
Unread post by sephult » 06 Jul 2017, 00:04
woohoo! I got too much stuff to work with!
Love your wavetables and super-oli addon packs though, awesome to hear!
-s
Unread post by 23fx23 » 06 Jul 2017, 15:38
great can't wait to test that as well ! :)
Unread post by oli_lab » 06 Jul 2017, 16:12
put osx version soonish
Unread post by oli_lab » 06 Jul 2017, 19:33
new version with clock input for consecutive wave command !
Unread post by oli_lab » 03 Aug 2017, 14:49
find it very unstable if inside a patch with preset.
should I implement the chunk system even if I don't save anything in preset ????
or is temp variable declaration in the process loop an issue ????
kind of make some NAN (not a number) on the output when preset are changed.
this is far behong my comprehension !
still working on it tho as I want to make the wave table circular...
Unread post by oli_lab » 05 Aug 2017, 22:08
up !
Unread post by 23fx23 » 07 Aug 2017, 17:15
couldn't deeply test yet but tried a bit sems very nice.
for the chunk i don't recall if you are obliged to implement, but i usually do as its nice not only for presets, but to store/recall variables on closing/reopening the patch too, it then store recall a 'chunk' too as i understand via those procedures. Maybe if you don't implement usine doesn't get right a valid size and it leads to memory problems tho it shouldn't i suppose, not sure if related to your issue.
Unread post by oli_lab » 09 Aug 2017, 02:08
23fx23 wrote:for the chunk i don't recall if you are obliged to implement,
you are right ! I checked the SDK exemples and many of them don't implement the chunk system.
I removed all the variable declaration from the onprocess() to the .h
still I have trouble when changing presetr, but not all the time... :/
Unread post by SylvainT » 21 Oct 2017, 11:00
Do you have OSX version?
Regards
Unread post by oli_lab » 21 Oct 2017, 11:48
yes !
http://www.sensomusic.com/forums/upload ... YOWTV3.zip
if you are keen to beta test the whole module library I'll be able to give you links soon
olilab101[dkjfhdkfh]gmail.com
Users browsing this forum: No registered users and 57 guests
