Still don't understand MIDI flows over racks/patches
La Tenaille
Unread post by La Tenaille » 15 Apr 2014, 09:28
I've done this simple patching with Midi loop (midi out go to corresponding midi in) to try understanding midi flows inside a rack :
I've set in1 ch1, in2 ch2, in3 ch3.
So the messages sent from rack 2 are mixed together and all sent to the three midi out, that's it ? No way to send each out to the corresponding device ?
About rack 1, it's the same : the messages in are mixed together ? How can I - lets say - send midi in 1 to patch 1, midi in 2 to patch 2 etc... ? Filters only ?
So at last, in order to avoid mixing messages together, it seems simpler to use midi buses inside each device, instead of puting the devices in the racks ?
Thanks for your advices
Unread post by nay-seven » 17 Apr 2014, 09:23
We're looking for solutions about the midi flux, but yes, in this case filters ( with different channels), or using the Midi buses are the best way
La Tenaille
Unread post by La Tenaille » 17 Apr 2014, 20:41
I've tried buses inside devices, it works fine. I've noticed the midi to usine module is needed to keep the midi learn abilty.
Blaakk
Unread post by Blaakk » 18 Apr 2014, 21:49
La Tenaille wrote:....... I've noticed the midi to usine module is needed to keep the midi learn abilty.
Pretty glad you wrote this. Saved me a lot of head-scratching.
ceasless
Unread post by ceasless » 23 Apr 2014, 01:00
Can you share a picture to save the world even more head scratching? :)
La Tenaille
Unread post by La Tenaille » 23 Apr 2014, 10:08
I've this in my device patch :
bus to patches and midi to usine for midi learn.
ceasless
Unread post by ceasless » 23 Apr 2014, 10:38
Thanks man! Sometimes a picture is worth a thousand words.
Blaakk
Unread post by Blaakk » 24 May 2014, 13:23
Here's another legal routing example... Image
I'd went and saved a ton of Kontakt presets in .fxp format, which I later realized were all set as channel 1. Yet I want them to be played with any MIDI channel, in this case, for example.... '6'. Rather than going back and changing (and resaving) all presets to 'omni', I just added a 'midi transform' in my midi device for each channel, changing them all back to channel 1 before they enter the 'CH 6' bus. So that's 16 channel 1's going to separate busses. ;)
Users browsing this forum: No registered users and 111 guests
