I have a problem that whenever I load my workspace my racks an audio out is added automatically even though I do not wish it to be added.
My racks are setup to feed into each other in a chain with only the final output going to my soundcard.
Is there a way to change this behavior. ? This is in the latest 64 bit version of hollyhock.
Audio out added to racks automatically
you're right
we 'll check this issue
What happens if you disconnect your soundcard on this main device (named out 1)
And you create your own one ?
Joffo's suggestion does fix the problem temporarily but it seems as if it is a bug. Default audio out should not be automatically added if the workspace is not saved that way. I made a custom audio out and bypassed the default one for now.
Users browsing this forum: No registered users and 139 guests
