XY pad mouse click detector
yes good idea.
also in the picture/bit map module.
I'll try to implement that soon.
jean-marc duchenne
Yes !
About the Trajectory module, could you make different colours or something else to distinguish points and interpolation lines ?
I will try to explain with an example...
If I draw a continuous square, it will result to a continuous variation of the values. OK.
If I draw only four points at the corners, Usine draws lines between them and it looks also as a square, but there is only four points and the values jump from one to another. It is also OK.
But when I look at the two figures, it will be useful to see what are the points and what are only "visual link lines".
yes I'll see what I can do.
Implemented in the next version.
As a "led" Mouse down witch has the value 1 when the mouse is pressed on the "bubble", 0 otherwise.
Users browsing this forum: No registered users and 81 guests
