workspaces in workspace
héliouk 6
Unread post by héliouk 6 » 24 Nov 2010, 21:16
hello usiners,
i have some workspaces that i need to put in one, to store each in ib module,to be able to pass from one to another without doing an open workspace each time.
is it doable easily or need to rewrite each workspace in the big one?
Unread post by nay-seven » 24 Nov 2010, 21:50
i suppose the best way could be to save each workspace as patches , then re_introduce/rebuilt them in the main one, and add somes patch on/off modules..
be also careful to target of buses if you uses them..
héliouk 6
Unread post by héliouk 6 » 24 Nov 2010, 22:35
ok i'll try . i didn't know that we can save a workspace as a patch.
thanks nay.
Unread post by nay-seven » 24 Nov 2010, 22:40
mm, no you can't save a workspace as a patch , i mean save a workspace as several patches and rebuilt this after...
héliouk 6
Unread post by héliouk 6 » 25 Nov 2010, 15:17
yes,that's what i thought...
héliouk 6
Unread post by héliouk 6 » 13 Jan 2011, 14:07
i did it,but it seems that the on/off module is not so efficient,and,even with all patches off,the cost in cpu is high because off the numerous patches inside.
Unread post by nay-seven » 13 Jan 2011, 14:46
mm, this is strange..how many patches...?
gurulogic
Unread post by gurulogic » 13 Jan 2011, 16:00
Have you considered the load workspace module? This in combination with putting modules that need to remain constant in a master patch, the load workspace module can be powerful. I think if it existed (wink-nudge) a "load track" module could also be usefull in this situation.
Unread post by woodslanding » 13 Jan 2011, 19:25
I note that saving tracks does not seem to save the settings for aux sends, etc, so you will have to make sure you account for that.
Users browsing this forum: No registered users and 131 guests
