I'm trying to use the "audiofile" class in the SDK to make a multitrack file but I get some errors :
My idea is to have a multitrack wave file that I can save (or load) and populate it with samples
But I think I get something wrong.
If I want to have a recorder like the "audios ampler recorder" module, do I have to save the samples in a buffer (RAM) and then use the audiofile to save the wave file to disk ?
I'm a bit lost in here.
in .h
TAudioFilePtr audiofile1;
in .cpp
// constructor
multitrackrecorder::multitrackrecorder()
audiofile1 = sdkCreateAudioFile();
// initialisation
void multitrackrecorder::onInitModule (TMasterInfo* pMasterInfo, TModuleInfo* pModuleInfo)
sdkSetChannelsAudioFile(audiofile1, numOfAudiotInsOuts);
sdkSetSizeAudioFile(audiofile1, 60 * sdkGetSampleRate());
When loaded in Usine, I get those error messages :
[4] Error :
bad pointer in SetChannelsAudioFile
[6] Error :
bad pointer in SetSizeAudioFile
any idea ?
thanks
Audiofile
Audiofile
Finally I will make some code from scratch with ofstream direct in C++ so I will be able to adress the metata datas in the wave file as well.
wish me luck
wish me luck
I had a go with the audiofile command las few days.
I managed to load wav files, but can't save any
here is the part of the code that's not working : (it's included in a function that is called at callback)
if I run it, it will return errors :
[2] Error :
[HydroGen OP V5] CallBack, paramIndex=19
tried with
sdkSetChannelsAudioFile(audioFile, 1);
sdkSetSizeAudioFile(audioFile, m_size);
before
for (int i = 0; i < m_size; ++i) {
sdkSetSampleAudioFile(audioFile, 1,i, m_buffer);
same thing
if I comment it and run only SetChannelsAudioFile and SetSizeAudioFile :
[6] Error :
[8] Error :
with only: sdkSetSampleAudioFile(audioFile, 1,i, m_buffer);
[2] Error :
with only: sdkSaveToDiskAudioFile(audioFile, tempChar, 1);
SDK_SaveToDiskAudioFile :
[0] Error :
PROC:SaveToDiskAudioFile
ERROR:Access violation at address 000000000136CDDE in module 'Usine.exe'. Read of address
0000000000001190
if anyone has a working example using sdkSaveToDiskAudioFile, could you please show it to me !
thanx
Code: Select all
sdkSetSampleAudioFile(audioFile, 1,i, m_buffer[i]);
}if I run it, it will return errors :
[2] Error :
tried with
before
same thing
[6] Error :
[8] Error :
[2] Error :
[0] Error :
0000000000001190
thanx
