Visual studio debugging 64 bit usine
Unread post by sm_jamieson » 04 Jan 2020, 19:58
I have just moved over to 64 bit usine hh3, and recompiled my own SDK modules. If I try to debug with visual studio 2017, the breakpoints do not work due to symbols not being loaded. The modules window hardly shows any modules and my user module dll is not shown. It all works fine for 32 bit usine.
Any ideas?
Unread post by senso » 06 Jan 2020, 09:51
hello,
Personally I use VC 2019 and everything works perfectly.
Maybe you can take a look on options of the project and verify that symbols are added at compilation time, in debug mode of course.
Sorry I can't help you more.
senso+++
Unread post by sm_jamieson » 07 Jan 2020, 01:54
Thanks. It is working now.
I had to select Native Code in the code type when I attached to the process.
The Auto setting was not working for some reason.
Users browsing this forum: No registered users and 57 guests
