If I output a fairly large number of trace lines in a short space of time using sdkTraceChar, only the last 100 lines show up in the trace panel or in the console panel.
If I use sdkTraceLogChar to output to the Usine log, the lines do not go missing.
It is as if the trace displayed in Usine is limited to a buffer size of 100 lines or something.
Before I raise as a bug, any comments on this ?
Simon.
missing trace output
I guess trace is quite slow. it works at bloc level
prob a design choice to remain descent on display but might be wrong
Users browsing this forum: No registered users and 57 guests
