wavetable generator
Unread post by oli_lab » 10 Mar 2016, 10:56
Hey !
I found these 2 softwares :
Audio term is analysis and resynthesis software
https://www.google.fr/url?sa=t&rct=j&q=&esrc=s&source=web&cd=4&ved=0ahUKEwiCuKq767XLAhWGiRoKHVQUALoQFggyMAM&url=https%3A%2F%2Fdl.dropbox.com%2Fs%2F1y0d88ts8zy1um7%2FAudio-Term.zip%3Fm&usg=AFQjCNEzut3WEMy6lTzrvtWCGzFmrZNNcw&sig2=hywmKphouSC2jcc4_gOQXg&cad=rja
and wave table creator is for building the wavetables...
http://lady.rdsor.ro/~kotro/index.php?m=soft
could be fun to make a wavetable reader as a module ?
any ideas of options ?
Unread post by 23fx23 » 12 Mar 2016, 14:25
looks cool! good idea.
Unread post by oli_lab » 18 Mar 2016, 12:40
Hi
I will need to open wave files from the module...
[s]Is C++ fopen up to the task ?[/s]
Oh, I'm starting to get somewhere :
every thing has been taking care of in the sdk :
//sdkLoadInMemoryAudioFile
//sdkGetChannelAudioFile
//sdkGetSampleRateAudioFile
//sdkGetBlocSampleAudioFile
//sdkGetBitPerSampleAudioFile
//sdkGetSampleAudioFile
I thinking also of a way to do wavetables in real time...
Unread post by oli_lab » 19 Mar 2016, 09:36
Hi ,
I'm stuck !!!!
I'm trying to load an audiofile from disk
in .h I did :
AudioFilePtr wavetable;
and in .cpp :
// constructor
WTsynth::WTsynth()
wavetable = sdkCreateAudioFile(); // this bit does not work and the module does not create itself while loading in Usine.
// destructor
WTsynth::~WTsynth()
sdkDestroyAudioFile(wavetable);
I tried to remove "wavetable = sdkCreateAudioFile(); " from constructor and put it in Oninit : not working either...
Unread post by oli_lab » 22 Mar 2016, 09:36
up !
I'm still stuck on that one !
Unread post by 23fx23 » 23 Mar 2016, 14:39
at some point i also tried to do the reverse, place some arrays of float into a file using sdk audio files commands and save to disk but i could never succeed, miss something as well sorry.
an audio file creation/load/manipulation/save sdk exemple could be cool !
Unread post by oli_lab » 23 Mar 2016, 15:01
+1
we need an exemple indeed !
sephult
Unread post by sephult » 23 Mar 2016, 18:19
That synopsis software looks cool. I just bought a Blofeld too, thanks for sharing. Will be cool if could get live wave tables goin in usine
Unread post by senso » 24 Mar 2016, 10:06
Actually the
are not functional in HH2.
sorry
Unread post by oli_lab » 24 Mar 2016, 11:04
ok,
I'll try with ole C++
Users browsing this forum: No registered users and 68 guests
