popup panel minimum size
Unread post by sm_jamieson » 25 May 2026, 17:53
For some reason the popup panel has a minimum width of 120px. For comparison, you can set the height down to 0 if you want.
I want a very small popup window - less than 120px wide, so the only way is to use the zoom factor to make it smaller.
Anyone got a workaround for this ?
Unread post by oli_lab » 25 May 2026, 18:27
The only workaround I see is the zoomfactor !
Otherwise you can ask Senso that this issue is adessed in the HH7 version !
Unread post by sm_jamieson » 25 May 2026, 19:32
Yes. In the old days Senso would look at these forums every month and reply - not so sure now. I'll put this in the suggestions forum.
Unread post by sm_jamieson » 25 May 2026, 19:49
I had forgotten that the container can also be made floating and I'm not sure if there is much difference between the popup and a floating container window. And the container can be made much smaller.
Unread post by oli_lab » 26 May 2026, 08:29
you can use the "is additional container" option
Unread post by senso » 26 May 2026, 09:47
I'll try to reduce the min sizes in the next major releases.
Users browsing this forum: No registered users and 320 guests
