enable / disable patch from switch
Unread post by sm_jamieson » 17 Mar 2021, 16:00
I am still on HH3.
When a patch is displayed there is a little camera symbol for presets and a small arrow to enable and disable the patch.
If the array is red, the patch is inactive and using no CPU.
Is there a way to control the arrow switch from a patch ?
I want to be able to enable and disable an effect patch with a large switch instead of having to use the tiny arrow button.
I looked in the patch settings module but it does not seem to be in there.
If not in HH3, can you do it in HH4 ?
Simon.
Unread post by SylvainT » 17 Mar 2021, 16:11
You can use the "Patch On/Off" module to activate/desactivate your patch dynamically.
Sylvian
Unread post by sm_jamieson » 17 Mar 2021, 16:58
Thanks, I didn't know about that.
I've also realised I can send a bind to that button.
Unread post by sm_jamieson » 17 Mar 2021, 17:08
I've looked at the manual. What is the difference between Patch ON/OFF and patch Bypass ?
Does Patch ON/OFF mean that the audio flow will be blocked at that point in the rack ?
So if I want to switch off an effect patch in the middle of a rack I need to use bypass ?
Unread post by sm_jamieson » 17 Mar 2021, 17:26
Its OK I found the answer on a forum search.
Users browsing this forum: No registered users and 48 guests
