Send trigger when volume decrease
Hi every body.
I need to trigger something when the sound decrease. It seems so simple, but i try to explain.
I hit a cymbal that go thru an FX. This FX is very loud and sunddenly it decrease very speed.
I need to trigger something when the sound decrease. But the volume is never the same. I can't work with a db value threashold because the db Value depend of the power of the hit on the cymbal. But the FX is always Loud ans suddenly low.
I try with an envelope follower and array average but it didn't do the job beacause it need a db threshold value.
I think i need something to calculate the difference between loud sound and low sound. When the difference is more than X db, so send trigger.
i try with array without success.
Somethink to store the max db value and when the next value is X db under, it send a trigger...
Thank you to help.
Thank you to help.
Interesting problem.
I will have a look at it later.
But maybe you have something to do with the module "array standard deviation".
Maybe it's a solution.
You had to adjust the release time of the two envelop followers according to your sounds, and then the threshold.
All the best
All the best
i will have a look to it, and i'll tell you.
Thank you very much.
It is work.
It needs attention to adjust, threshold and the release time of the two envelop followers, but it seems work.
i will play with it for a reharsal soon. I will tell you.
It works fine and it is funny to play. When i'll have some free time i'll think about some improvements.
Users browsing this forum: No registered users and 245 guests
