Syncing Samplers
Syncing Samplers
Hi all. I have several audio sampler modules working together playing audio files. They are comanded by a single PLAY button. They sometimes get out of sync. I need them to work in perfect sync, PLAY-STOP, cursor position, etc. I know there's a way to sync them together but I don't know how to do it. Any help will be greatly appreciated,
Hello. 198 views and no replies. This seems to be an easy issue to solve... I just don't know how to do it properly. Where are the experts of this forum?
198 views are probably bots browsing the forums.
for your sync question, it depends what you really want to do :
if all your loops are the same tempo, basic samplers set to "cycle" loop mode and master tempo set to the same value should do.
if loops are different tempo, you'll need "grain samplers", compute speed based on secondary sample duration / primary sample duration and drive the "speed" of the secondary sampler. also use the restart output of the primary sampler to restart the secondary sampler
Users browsing this forum: No registered users and 88 guests
