record midi control
hgermain
record midi control
Unread post by hgermain » 06 Feb 2023, 20:30
Simple (dumb?!) question, but i really can't find the answer :
how can i record the movements of a midi controler (LIvid DS1, or nanokorg ) ?
in a way that i can playback the midifile (wich would reproduce the actions) and edit it.
eh a piano roll doesn't seems to record it
if anyone knows i'll be thanksfull !
Hughes
Unread post by senso » 07 Feb 2023, 12:09
Use the patch /Data/Manipulation/data-manipulation-rec-xy.pat
hgermain
Unread post by hgermain » 09 Feb 2023, 17:28
Thanks Senso. that works...
in fact the piano roll do record everthings done with the midi controler, but don't show it.
(checking the file in reaper show the knobs movements)
it could be interesting to have a patch "midi rec", that show the tracks used ?
i'm thinking of this while recording my performances, with the ability to edit it later, but not in audio.
but for the moment, i can't play back the midifile in a way that makes move the automation done in midi learn, just like when i move the knobs...
Unread post by senso » 10 Feb 2023, 08:59
It's an old request: be able to record live-session. But the main issue for us is the huge amount of data you can record:
- midi controllers
- random generators
- sensors values
- osc inputs,
- etc...
this can represent Giga's of data's...
And then, how you can edit recorded datas ? with thousands of automations curves?
hgermain
Unread post by hgermain » 10 Feb 2023, 13:59
ourgh you're right things get waaay too big !
i'll keep it simple, record the two midi controlers with piano roll,
and edit the curves if needed in reaper.
thanks.
Unread post by gwennaelle » 07 Jul 2025, 21:25
I would like record midi automation. How do you do ?
Senso, How do you use the patch /Data/Manipulation/data-manipulation-rec-xy.pat ?
Hug Germain, I don' understand this "record the midi controlers with piano roll, and edit the curves if needed in reaper." How do you do ?
Thank you
hgermain
Unread post by hgermain » 18 Jul 2025, 20:23
hello Gwennaelle, sorry i didn't saw your message. you might have found how to do ?
> create rack, put on the input you midi control device
> in the patch put the piano roll module
> hit record / stop
>when you click on the recorded midifile in the pianoroll module, in the menu you can export the midi file.
and then open it in reaper, to edit the file as you want.
i'm more an audio guy than midi ! hope this help !
Unread post by senso » 31 Jul 2025, 09:04
to use the data-manipulation-rec-xy.pat just connect one of the 2 inputs to what you want to record and click on "REC"
hgermain
Unread post by hgermain » 04 Aug 2025, 16:58
Awesome & simple ! always something to learn. thanks Senso
Unread post by oli_lab » 20 Aug 2025, 22:20
check the "event recorder V2" from Oli_Lab !
records datas, play at any speed etc...
you should use external arrays to have recordings saved in preset, see example.
Users browsing this forum: No registered users and 270 guests
