Convolution ?
moody33
Unread post by moody33 » 13 Jun 2008, 14:06
I was asking myself if it's possible to build a convolution engine in usine? If, yes , how to?
Any idea?
Moody.
Unread post by senso » 13 Jun 2008, 18:56
Actually no way to make a real time convolution with Usine modules but you can find lots of free VST (like SIR).
Did you try them?
ethnix73
Unread post by ethnix73 » 13 Jun 2008, 18:57
It might be a really big and difficult work. I'm unable to help you....
Seb.Dub
moody33
Unread post by moody33 » 16 Jun 2008, 14:48
Ok, thanks you for your answer. I'd try Sir and I love it, but 8840 samples latency, is too much !
Any suggestions? ( for free..)
Kaspar
Unread post by Kaspar » 17 Jun 2008, 08:21
Is it possible to use convolution based guitar amp sims as a reverb unit by just loading a reverb impulse?
Then you could use Boogex or Kefir.
Come to think of it, they are probably mono...
moody33
Unread post by moody33 » 17 Jun 2008, 12:11
Good idea Kaspar. I've not test yet , but the impulse response is probably limited to one or two seconds with boogex. I will try.
Users browsing this forum: No registered users and 36 guests
