script command to get list of files in folder....
Unread post by woodslanding » 07 Sep 2021, 05:36
I have my presets on disk in folders by instrument, and then subfolders for banks, and I'm organizing them as time goes by. Soon I'd like to start using master presets... but it's very likely a preset might have moved from the folder it was in when the global preset was saved. So I'd like to write a script to check other folders for a preset with a given name.
Does anyone know the scripting command for getting a list of subfolders in a particular folder? A list of file names? I did not see anything in the manual...
Thanks!
Unread post by senso » 07 Sep 2021, 07:47
Actually, there is no such instruction for that, I'll implement that.
Unread post by woodslanding » 29 Sep 2021, 19:40
let me know when you do, so I can try it out....
Users browsing this forum: No registered users and 31 guests
