Did someone work with Touch OSC Bridge ?
This utility allows you to use Touch OSC as a Midi control surface. Touch OSC Midi then appears in the Devices.
It seems to work. I can do Midi learn from Touch OSC on my Iphone. However, it is impossible to send Midi Out.
I have activated Touch OSC MIDI OUT in the general settings. I put the Touch OSC OUT device in the output of the rack, I tried to configure it as a motorized control surface. But no MIDI information comes out of Hollyhock.
Has anyone ever experienced this problem before?
Is it a bug from TouchOSC Bridge for Mac OSX ?
It's a pity because it would save me from creating OSC Sends for feedback to the Iphone.
Thank you very much.
Touch OSC Bridge
Don' t have Iphone , but will test on android
is there a reason you don't use direct OSC ?
i test Osc feedback for each version we provide and it works here
I need feedback on my Iphone. For example, I activate a switch in HH and a LED lights up on my Iphone. And vice versa.
I don't know how to get this feedback simply via OSC.
This is not a TouchOSC bug, because everything works fine with Live.
ok, just test and it works here with last Usine version on Mojave system
Have you set both the fader and the device Out TouchOSC Bridge as motorized ?
YES !! Thank you.
I had forgotten to set the device out TouchOSC Bridge as motorized !!!
cool, have fun !
Users browsing this forum: No registered users and 34 guests
