Hi
how can i block one cc number (in this case cc20) yet allow all other cc's to pass?
thanks for the help!
block one specific midi cc from reaching a vst
I guess you put MIDI Filter and set it to track this CC, and then put Stop flow from MIDI input to trigger when specific CC passes?
No need of Stop module,
Use the Multi MIDI filter, set the CC 20, and use the reject outlet for other CC's
thanks Nay. that was so easy and works perfectly. Thank you!
Users browsing this forum: No registered users and 189 guests
