Screen Resolution Script
dmitriyc
Unread post by dmitriyc » 24 Nov 2018, 17:14
Hey all.
Was wondering if there was a script or something to get my current screen resolution and preferably spit it out as a numerical output?
Unread post by nay-seven » 26 Nov 2018, 20:12
not currently, but maybe a script guru can create one for U ;-)
Unread post by 23fx23 » 26 Nov 2018, 23:55
maybe try this one:
(paste all in empty script and press compile and init, then 'get rez' button)
Code: Select all
// Extract rez from usine log
// declaration
var refresh,textOut : Tparameter;
var Xout, Yout : Tparameter;
var st   : TStringList;
procedure init;
var i : integer;
begin
  refresh := CreateParam('get_rez',ptButton);
  SetIsOutPut(refresh,false);
  textOut := CreateParam('text',ptTextField);
  SetIsInPut(textOut,false);
  Xout := CreateParam('X',ptdataField);
  SetIsInPut(Xout,false);
  Yout := CreateParam('Y',ptdataField);
  SetIsInPut(Yout,false);
end;
// read
procedure ReadTextFile;
var all : string;
var line : string;
var position :  integer;
begin
  st.create;
  st.clear;
  st.loadfromFile(GetApplicationPath + 'LogUsine.log');
  all := st.GetCommaText;
  position :=  pos('Resolution',all);
  if(position>0) then begin
   position := position+11;
   SetStringValue(textOut, copy(all, position, 9));
   line  := copy (all, position, 4);
   SetValue(Xout, strtoint(line));
   line  := copy (all, position+5, 4);
   SetValue(Yout, strtoint(line));
  end;
 // itrace(position);
  st.free;
end;
// Callback
procedure callBack(n:integer);
begin
  if n=0
  then
  ReadTextFile;
end;
dmitriyc
Unread post by dmitriyc » 27 Nov 2018, 18:14
23fx you are a genius! This is perfect. Exactly what I was thinking! Taking the log that Hollyhock makes and reading the string text directly from it! You are the man!
Unread post by 23fx23 » 27 Nov 2018, 22:33
cool if usefull :)
Unread post by rlgsbt » 28 Nov 2018, 07:51
GREAT ! thanks 23fx
Unread post by 23fx23 » 28 Nov 2018, 12:19
note that can only work if resolution is set before launching usine, as log is created here,
will not work if changing res while usine is already launched, but maybe possible with sdk im not sure, ill try to have a look.
dmitriyc
Unread post by dmitriyc » 19 Mar 2021, 03:58
Hmm...Doesn't seem to want to work anymore. I tried revisiting an old project and got an error on line 6 column 21. Can't make heads or tails of the code. Please help with update?
Unread post by senso » 19 Mar 2021, 19:53
this code works on:
Code: Select all
// declaration
var refresh,textOut: Tparameter;
// initialisation create parameters
procedure init;
var i : integer;
begin
  SetIsOutPut (refresh,false);
  SetIsInPut( Xout,false);
end;
// read
var all : string;
var line : string;
begin
  st.create;
  st.clear;
  if (position>0) then
  begin
  end;
  st.free;
end;
// Callback
procedure callBack(n : integer);
begin
  if n=0
  then  ReadTextFile;
end;
dmitriyc
Unread post by dmitriyc » 31 Mar 2021, 23:17
Thank you very much Senso! Very slight correction to your code:
should be
st.loadfromFile(GetApplicationPath + '/LogUsine.log');
the format was a bit off and was spitting back an error.
Quick follow up question: is there any way to just simply print the GetApplicationPath?
Unread post by senso » 01 Apr 2021, 09:37
what do you mean by "print"?
dmitriyc
Unread post by dmitriyc » 14 Apr 2021, 23:28
i would like to use the PC path that usine is on as a string text to call up and execute .bat files. So instead of resolution, I get "C:/Program Files/Usine Hollyhock/". Then I am able to add the .bat file that is in one of the folders and execute that way by calling up the path and then inserting the command. Hope that helps...
Unread post by senso » 16 Apr 2021, 20:50
not sure to understand,maybe you could take a look on
https://www.brainmodular.com/manuals/hh ... usine-path
Users browsing this forum: No registered users and 32 guests
