Need help with a "Logical Gate"
lytz1
Unread post by lytz1 » 03 Feb 2017, 22:57
So here is the thing:
- Random Values Generator outputs float values between 0 and 1.
I have it connected to a A>=B which goes into a fader that is controlling dry/wet.
I want the dry/wet fader
- full wet when random value is above 0.80
- dry when below 0.80.
But A>=B doesn't work because it stays full or off (1 or 0) until the next trigger arrives.
So I am a bit stuck now.
Quick solution somebody?
Thanks in advance,
tL.
gurulogic
Unread post by gurulogic » 04 Feb 2017, 00:43
Hmm.. I can try to help but I am not sure I fully understand what you are trying to do. When I try with your method, it seems to behave as expected by the first part of your question and the wet fader is at 1 when the input is above 0.8 and at 0 when the input below 0.8, but this is not the desired behavior?
Blaakk
Unread post by Blaakk » 04 Feb 2017, 01:00
Do you mean the fader only stays full for one step, even if the next step (change of value) is also over 0.8? It should indeed work if your b value is 0.8 and 'block' is turned off.
Is your fader's min and max set to 0 and 1? Have your tried repairing the ID's? Conflicting ID's from copy and paste actions can sometimes have undesirable effects.
lytz1
Unread post by lytz1 » 04 Feb 2017, 12:57
Thanks guys! I checked all the steps again and followed Blaaks advice as well.
Now it works, I am just not sure which particular point made it work...
Thanks again,
tL.
