Hi
For an installation I just installed HH last version on an old PC Win7 32bits.
My patch works perfectly, but I don't manage to see my VST plugs.
I run the usual procedure: choose my vst folder, scan for vst in the setup pannel
Once scanned, they just don't show up in the plugins browser, which remains empty...
I tried to download new VSTs, which are for sure compatible with my 32bits system, but same thing.
Any idea ?
vst don't show up... again
do the VST show up in other 32bit DAW ? (try to download tracktion 4 32 bit and test it)
I did try in Tracktion - didn't know this soft -, 32bit version, the VST do show up...
They show up in Reaper 32bits too.
Usine 32 bits needs 32 bits plug ins, there 's no bridge like in Reaper.
Are you sure you have installed the 32 bits version of these plug ins ?
Yes Nay, I know that and I loaded 32bit VSTs like Voxengo Sound Delay for example...
Nothing...
Nothing...
Can you open the usine/config/plug ins folder ?
you'll find several .init files you can open with a simple text editor
check your vst appears in the Knownplugins.init file , you can also check what you see in the others init files
Users browsing this forum: No registered users and 38 guests
