Hi
There is something I can't figure out about controlling Usine via OSC.
I use TouchOSC on a smartphone and I control my patches thanks to an OSC lister module.
But when I modify this OSC lister located in my Devices/In section, the change is efficient for ALL my workspaces. For example, I happened to erase the OSC lister in a workspace and then it got erased in all my projects.
Same for the OSC out...
Can't they be independant from one wkp to another ?
different wkp = same OSClister ?
You will need to make individual device patches for any configuration you want. The device patches are global, but you can make a new one for any purpose you want, and they can all talk to the same hardware at the same time (at least unless I am mistaken).
Doyou mean something like that :
And you only activate the patch you need according to your workspace ? (here OSC in device 13)
big advantage of using devices instead of putting osc modules in racks is that they take ressources only when receiving or sendind OSC.
Users browsing this forum: No registered users and 156 guests
