Sync Looper to Odd Meter
Ariajazz
Unread post by Ariajazz » 07 Jul 2014, 05:34
Hi guys, I need your help again. I need to sync a looper with a 7/8 meter so it starts recording (preferable triggered by audio signal) stops recording after two bars and have the options to play the loop manually or/and autoplay. I need some help in how to set global or local sync to achieve this.
thanks in advance
trik
Unread post by trik » 07 Jul 2014, 11:53
From the top of my head, I'd say:
connect the 8 led out from the master sync to a switch counter that counts to 7. These switches can toggle record and playback.
Ariajazz
Unread post by Ariajazz » 07 Jul 2014, 15:29
Thanks trik for replying. I don't get the idea, which master sync?? can you be more specific? thanks
trik
Unread post by trik » 07 Jul 2014, 18:42
Ariajazz wrote:Thanks trik for replying. I don't get the idea, which master sync?? can you be more specific? thanks
There is a module that controls the master tempo of usine.
here it is in the manual.
You connect its 8th led output to the input called 'next step' in the module for sequenced switches. here
With this module you can then control the play and record inputs of your sampler.
seamus
Unread post by seamus » 07 Jul 2014, 18:45
which looper are you using? Mobius can sync to host and then it just follows whatever the host counter is.
La Tenaille
Unread post by La Tenaille » 07 Jul 2014, 18:45
Why using a counter ? I've already set master sync or local sync to 7/8 in the list of bars. It works fine.
seamus
Unread post by seamus » 07 Jul 2014, 18:58
what looper are you using la tenaille?
La Tenaille
Unread post by La Tenaille » 07 Jul 2014, 21:47
I use mobius, but I've never tried 7/8 with it. I thought you were talking about a looper made with Usine.
I can give a try if you need.
Ariajazz
Unread post by Ariajazz » 09 Jul 2014, 02:47
I use GLoop by GVST wich is fine looper for even meters but I can't make it work for 7/8. I've tried Mobious in the past but it is too complicated and takes a lot of time and tweaking to make it work right. I would consider using a looper made with usine since this software is very powerful but have no idea where to start, probably using the REC feature of the wav sampler set a loop mode with the syncro function
seamus
Unread post by seamus » 09 Jul 2014, 09:42
I was using möbius but I'm trying echoloop. It seems to work better than möbius jbridged to 64 bit. It's simpler with less features but seems to offer less problems when switching workspaces.
Ariajazz
Unread post by Ariajazz » 10 Jul 2014, 17:23
Does anyone have an idea to buil a looper like this with usine???
La Tenaille
Unread post by La Tenaille » 10 Jul 2014, 22:34
I'd love a reliable live looper inside Usine, and I know I'm not the only one. Mobius as VST is powerfull but so hard to synchronize... at last I've built a script that resync Usine each time a loop starts :| And the integration is hours of head scratching.
Unread post by nay-seven » 11 Jul 2014, 10:47
I know that you're a few looper user here, but maybe you have to create a complete and precise list of features you need and above all , why you don't use/like patches like bar recorder, echoplexx and looper rc51 ?
then maybe some patcher can help you to built such a tool ( I'm afraid the team is busy with big updates for some weeks actually..)
Users browsing this forum: No registered users and 164 guests
