preset manager recall
seamus
Unread post by seamus » 04 Jun 2013, 21:56
is there a way to change the recall numbers in a preset manager?
if i use more than one preset manager in a patch i would like the second preset manager to respond to 16-32 and so on
i am using a 12step to send out values on each key (0-127) so far the preset managers can only respond to 0-15
seamus
Unread post by seamus » 04 Jun 2013, 22:01
perhaps this screenshot can help give an idea.
The long term solution is larger preset managers... but maybe there is a short term fix
seamus
Unread post by seamus » 04 Jun 2013, 22:17
perhaps some kind of dispatcher module... so i could with a button selected choose which preset manager i can control with the 12 step toggles module
Unread post by nay-seven » 04 Jun 2013, 22:39
I've found this old patch which can be a start,
you'll have to change the target of each preset manager, but can maybe suit your need
Download
seamus
Unread post by seamus » 04 Jun 2013, 22:59
i tried the above. I have to test if it works. it seems to at first glance.
thanks Nay for your patch i will check this also.
seamus
Unread post by seamus » 04 Jun 2013, 23:09
in the preset manager that you just gave me do i put my patch inside of it? It is a kind of shell ?
Unread post by nay-seven » 04 Jun 2013, 23:20
yes, i suppose you can , depending of the target you choose for the preset manager modules
seamus
Unread post by seamus » 09 Jun 2013, 10:01
I have found that when using your preset manager patch and changing the target to workspace that it is taking me up to 15 seconds with a white screen flash before the patch successfully switches. I wonder what could be causing this sluggishness.
seamus
Unread post by seamus » 09 Jun 2013, 10:16
i suppose its due to the complexity of one of my patches which is a midi harmonizer with lots of internal subpatches it is getting bogged down. Too bad cause in Usine 5.80 the conductor could handle this task quite well.
Unread post by nay-seven » 09 Jun 2013, 10:21
I can't explain cause i can't reproduce it here...
if you can create a simple workspace where you can reproduce it, you could add this to the bug report page..?
seamus
Unread post by seamus » 09 Jun 2013, 10:30
Yes of course. That is a logical way of going about it.
Thanks!
seamus
Unread post by seamus » 09 Jun 2013, 10:43
Is there a way for a rack or patch to ignore the workspace preset manger?
Unread post by nay-seven » 09 Jun 2013, 11:02
No, not yet
seamus
Unread post by seamus » 09 Jun 2013, 11:07
i also find that when i reload the workspace the presets are lost. reloading a workspace is starting from scratch.
Unread post by senso » 09 Jun 2013, 11:12
in the 1.00.237
seamus
Unread post by seamus » 17 Jun 2013, 08:09
nay-seven wrote:I've found this old patch which can be a start,
Download
i found that this 128 preset manager that you gave me Nay works until you reload the workspace then the presets are lost.
Has anyone else found this?
THe basic preset manager works and remembers the presets after a reload but not this larger one.
I hope that some larger preset managers come soon.
In the meantime i will explore the grid.
Unread post by nay-seven » 17 Jun 2013, 08:52
A new preset manager with 32 presets comes in v 237
Unread post by woodslanding » 17 Jun 2013, 19:08
32?
Is there a reason the number is still so low?? 128 is the midi standard..... I use 256 presets for kontakt in my V5 wkp currently, and may need to move to more as I'm about out of slots. Most synths have support for 500 or more. But I wonder why there even needs to be a limit? Max puts no limit on how many presets it can store......
I guess if there is a reliable script to piggyback them (which it seems there is not yet) it doesn't matter.
But it would be nice to see the multiple options for size we get with arrays, etc. And nice to use just one PM when you need presets for something.....
seamus
Unread post by seamus » 17 Jun 2013, 19:34
+1 for more than 32
I think 128 would be nice. That would meet my needs
This is my main stumbling block in hollyhock so far.
Although I am going to also try to work with smaller workspaces and switch between them.
shamanic bicycle
Unread post by shamanic bicycle » 20 Jun 2013, 20:52
don't forget usine is mainly designed for live and organic process in live conditions, as a musical instrument.
Too much presets often kill spontaneous live interactions in gigs and avoid flexibility.
I believe too much recall memory can strangly be a limitation in most of the different uses. ;)
But certainly it depends of the way you use the software, agreed.
Regards
Shamanic Bicycle
multiinstrumentiste - improvisation
mac OSX10.13 - interfaces Olilab Midi/Osc - RME FF800
My Vimeo Julien Lachal
Users browsing this forum: No registered users and 304 guests
