aux tracks
hollyhock please! In Usine 5.80 it is more like a traditional mixer.
nothing easier in hollyhock.
With the rack and the devices concept you manage your routing as you want !
For example create a new device with a reverb inside.
You just have to put any rack you want on it.
You can also create a rack with your reverb routed on your hardware output an drag any rack on the input.
i seamus. did you find my solutions usefull ?
Yes it's very useful. Thanks joffo! Is CPU usage the same for you in hollyhock as 5.80?
I am getting more clicks even at only 20% CPU in hollyhock. Probably there is more optimizing to be done.
Is there any way to show an aux send in the usine mixer object?
I like the new mixer, but I don't need an input control, and I would like an aux send....
There is something that i use a lot with Usine, it is the possibility to send a track on an other track on the fly.
For exemple i have a pitch shift on track 1. A delay on Track 2. And a REC-Sampler on Track 3 etc ... I don't realy kwow what will be happening and how i will play with them. It depend about what the other musicians will play, and what sounds will come in my microphones ...
So i can decide for exemple to send the track-1 on track-2 and suddenly send the track 1 and 2 on track 3 for recording a sample on the fly, and send the Track-3 on track-2 etc ... there is a lot of possibility that i can use and decide on the fly. It is very easy with the Aux Send.
With Hollyhock i feel a little bit more close. I don't find the way to work with this flexibility ... Is there a way to manage something like that ?
Users browsing this forum: No registered users and 28 guests
