parent container/master container??
ErotiCore SteNch
Unread post by ErotiCore SteNch » 13 Aug 2011, 17:28
can someone explain to me how to set a parent/master container and can that container be used by multiple tracks?or is that just my wishes,(without knowing how it works)
Unread post by nay-seven » 13 Aug 2011, 18:06
Container are like panels and are useful if you want to group controls inside a single entity. here a little patch to illustrate :
download
but a container can't be shared by multiple tracks, it's just a kind of folder in a patch
ErotiCore SteNch
Unread post by ErotiCore SteNch » 13 Aug 2011, 18:11
thanks
but whats the different between maincontainer or parent container and a ordinary container?
it could be cool IF a container could be shared by multiple tracks though i guess that would be insanely diffucult to manage:)
Unread post by nay-seven » 13 Aug 2011, 18:27
it's the same hierarchy target than for control panel. in my example, choose the fader named fader in sub container and change his option
where= container
for
where = parent container
i know this concept is not always easy at first
Unread post by nay-seven » 13 Aug 2011, 18:48
can be confusing at first but really useful when you have for example some group of switches to move ...
will try to built a wiki page about hierarchy in Usine.
ErotiCore SteNch
Unread post by ErotiCore SteNch » 13 Aug 2011, 19:44
thanks,i think it all will make much more sense when i get a bit more used to usine.and i already have gotten alot of help on this forum for that i thank you:)
protofuse
Unread post by protofuse » 15 Aug 2011, 19:08
how to "attach" some elements to a particular container ?
the where property doesn't seem to be enough (I mean, I missed something else for sure)
protofuse
Unread post by protofuse » 15 Aug 2011, 19:17
I just missed something: my children element was at the bottom of a non-autoresizable container (so I didn't see it anymore)
btw, it works fine!
