Hi Senso, would it be possible to have imported vst's automatically insert the vst's name into the show & bypass buttons?
also, if i drop a vst on an audio link for it to automatically insert itself in the audio path (in stereo if necessary)? i know this might not always be something people would want but for me it'd save time patching things together a bit...
similarly if i drag and drop a vst onto an existing one maybe have the option (ie ask 'replace - yes [button] - no [button]) to replace it in the signal chain & update the show/bypass button names.
if it's not stretching the friendship too far can i ask how the search function in the browsers coming along?
if there is ways to do any of this already i apologise in advance - i've been looking through the manual a fair bit but i often get distracted by things other than what i'm looking for - Usine does so much!!!
regards
C
Couple of suggestions
The search engine in the browser is in progress (unfortunately only in my mind...)
The insert vst in the flow chain is a good suggestion but not so easy to implement. Someday it will arrive...
To replace a vst (or any module) by another :
- select the old vst (or module)
- drag & drop the new one from the browser with [Alt] pressed.
Users browsing this forum: No registered users and 181 guests
