About Patch Info
Vincent
Unread post by Vincent » 03 May 2008, 21:22
Hi again,
Thanks Olivier for your answers in the other threads.
- An easy one: I was thinking to a small patch info button on the patch interface panel, like this:
Image, for example.
- Another idea was to suppress the last red point of the curves (except for the default 'volume', maybe), to make the curve always horizontal after the last custom point (like in Cubase). Much more easier to tweak!
- A last one for today: when you 'click+vertical-drag' between two points, it mooves the entire curve; it could be nice to 'CTRL+click+vertical-drag' to moove only the choosen segment (only the first left and first right points).
vincent michel
composer & novelist
Unread post by senso » 06 May 2008, 23:42
thanks for your suggestions
I'll keep those suggestions in mind.
Vincent
Unread post by Vincent » 07 May 2008, 00:04
Thanks!
vincent michel
composer & novelist
Users browsing this forum: No registered users and 121 guests
