Page 1 of 1
Popup panel minimum size.
Posted: 25 May 2026, 19:34
by sm_jamieson
For some reason the popup panel has a minimum width of 120px. For comparison, you can set the height down to 0 if you want.
If I want a very small popup window - less than 120px wide, the only way is to use the zoom factor to make it smaller.
Can this restriction be removed ?
Thanks.
