Page 1 of 1
remote output
Posted: 31 Oct 2023, 16:52
by Gilsornette
It could be useful to have a remote output sending trigger as the mouse down output is doing. Thank you
Re: remote output
Posted: 09 Nov 2023, 10:18
by SylvainT
Not sure I really understood your request. Can you be more precise ?
Re: remote output
Posted: 06 Jan 2024, 16:16
by Gilsornette
Sorry Sylvain,
I did not see your answer.
When moving e.g. a fader with the mouse we can use the mouse down output to know it the fader is activated by an external gesture.
But if there is a remote on this fader (Midi controller) it seems there is no way to get such information.
That's why I was asking for a "remote output", sending trigger when activated.
Re: remote output
Posted: 07 Jan 2024, 15:43
by oli_lab
an "has changed" module on the fader output would do the trick ? except if you want to dissociate data coming from the remote and data coming from the mouse, in that case :
attack is 0ms and release is 200ms
Re: remote output
Posted: 07 Jan 2024, 21:50
by Gilsornette
Thank you Olivar,
But what I need is to get the info if a remote (OSC, MIDI...) is controlling the fader (or another object) . If I'm not mistaken the "has changed" module
would send datas also if there were a recorded automation or some modulation sent to the fader.
