hi,
I noticed one or two things on this module while it evolving.
We have no more "show loop" inlet to control this by patch.
in fact, i'm using this to visualise if the connected sampler is active or not :
-sampler active=show loop.
-sampler inactive=don't show loop.
It was ok with the 3.34 version cause even if the inlet wasn't here, my workspace load and work ok, But with the 3.5 version, it's no more the case, and i loose patch control on the show loop.
plus in the 3.5 version, it seem's that the "show loop" switch isn't updated until i drag the pos request slider, wich is bad.
to resume, wath i need it to be able to control the background color (light blue or grey) just to have a visual feedback (until now, i used the "show loop" for this) that mean : sample is active, or sample is inactive.
hope it's clear
waveform behiavor
martignasse
It's a mistake.
I'll reintroduce the show loop inlet.
martignasse
cool, thanks
Users browsing this forum: No registered users and 187 guests
