Hello Olivier,
Please Please Please, it would be very fine if the sequencer midi file module player (in the template sequencer ) have got the choice of midi files (like in piano roll module, 8 files possibilities), no add the loop control in this module, just a choice of midi files.
Two questions:
In this module (when I open score), some notes are in red color, why ?
How is it possible to modify velocity notes (in score open) when 2 notes or more are in the same position.
I m waiting this option (choice of midi file) with much impatience.
Thank you
Franck
Suggestion, another..
thanks for suggestions
The actual Sequencer Midi player is designed to be simple as possible to fit as in common audio softwares. If you have to build a more complex patch why don't you use the pianoroll module in your sequenced patch?
The red notes are marked as invalid: the don't contain the 'NOTE OFF' event but only the 'NOTE ON'.
To adjust the velocity, scroll the piano range (C1-C10) to make the second note disappear. I hope I'm clear.....
Users browsing this forum: No registered users and 151 guests
