Posted: 20 Aug 2007, 13:46
- An inlet and an outlet with the full path file name could be interesting to automate sampler file between several instance: sampler 1 record, then save, then send the recording file to another sampler.
-I'm not sure of this, but usine don't seems to put some modules in sleep mode. Could be intersting that modules that don't receive/don't send any value change entering in " sleep mode ". Don't know if it's possible.
When you say in the manual " as if the wire was delete" about the pass/stop modules, does it means that it consume less cpu?
-Audio :
- More "aux send bus" ( 4 in total? Mmmm)
-"Additional audio output module" : possibility to send the signal in tracks, and/or aux bus. Not only to output 1,2,3,...
- Insert patches in the mixers.
-Midi pianoroll: Ok, ok.......I know, you need to sleep.
-Think I've found a bug: when recording in overdub mode, the waveform display is not update. Only the first pass is show on the waveform display.
Thanks you for your great work.
-Audio :
