I found the startplay outlet on the sampler, but no stopplay outlet.
It could be usefull to trigger something after the end of a sample.
If i'm wrong, please excuse me, I'm a newbie.
Rgds
StopPlay for the sampler
Ok, good idea.
It can also be something like "Is playing" outlet with a value 1 if the sample is playing 0 otherwise.
I'll try to create it as fast as possible.
If you cant wait you can create a subpatch to send a trigger if the position>99%
thanks for your feebacks
Vincent
That's goody good. Sure we can, specially for good things. I've already done this control of position<100% (or >=99%, why not), but "Is playing" will be the solution.senso wrote:Ok, good idea.
Thanks!
Users browsing this forum: No registered users and 174 guests
