Page 1 of 1
Posted: 05 May 2011, 14:25
by joffo78
Hi
I noticed when i try to modify the value of the x1 or y1 of a xy pad in symetric mode i can see the second ball moving but the output value isn't modified. Isn't it a paradox ?
Posted: 05 May 2011, 15:09
by nay-seven
strange, just test : I've add 4 faders to the outlets x1,y1,x2,y2 and test the 3 symmetric mode
all seems ok here.
edit : but i suppose you mean you use the inlet of this module to change the values, so the mouse down is always off..?
Posted: 05 May 2011, 15:45
by joffo78
ok take a look please of my patch : example midi surround panner
try to draw a trajectory and see the output of x2 y2
Posted: 05 May 2011, 16:12
by nay-seven
yes, I've understand correctly, it's because the xy module wait for a mouse down information and with your use you don't have this, don't know if it's a bug or not
waiting for this here a workaround :
you can also notice i've delete the first 1-x between the draw trajectory and the XY module, for this just edit the layout of the draw trajectory and choose inverse y axis
Posted: 05 May 2011, 16:42
by joffo78
ok
first to have the good movement i had to conserve 1-x and invers axis on the draw trajectory and even my xy pad !
thank you to had a look i had this multiple variable to choose between symetric x or symetric xy :
Posted: 05 May 2011, 17:31
by nay-seven
ok, I've transmit the problem to senso anyway
