a way to delete last track added..?
maybe a way to confige usine ( in setup ) to stop audio engine when minimize..?
could be usefull to edit a sample in an other software
a way to name a patch in the grid window without to save it as a patch before..?
yet asked but when i close usine , could be cool to have a
" the current workspace has been modified
do you want to save changes , yes , no ,cancel... "
questions/suggestions
thanks for feedbacks,
A lot of other stuffs like that: insert, delete, move...a way to delete last track added..?
I'm not sure I understand the reason?maybe a way to confige usine ( in setup ) to stop audio engine when minimize..?
Yes I'll see what I can do.could be usefull to edit a sample in an other software
Dangerous? Actually you can rename the track.a way to name a patch in the grid window without to save it as a patch before..?
If you insist!!!yet asked but when i close usine , could be cool to have a
thanks to listen senso..
about stopping the audio engine , an other example : i record some tracks , and want to check the result in winamp , for that i've to go in the setup panel and stop the asio4all driver , if not winamp give me an error..same if i made a pause in my creation and go on website with music streaming ( myspace for example..)
but time to time i made a little change to a song , then phone or a visit , forget my changes and close usine without saving...i know i've a little HD for brain...
don't want to bother you with that...if you insist..
It's not only 'stopping the audio engine', but close the driver, cleanup the memory, etc...about stopping the audio engine
If you make sound design I suggest you to buy a 'multi client' sound card that allows the playing of multiple applications simultaneously.
Don't you think it's finally simpler?
strange cause i've a an edirol audio capture UA-20 as soundcard and i can run winamp +myspace+ soundforge...in the same time
so...
so...
Users browsing this forum: No registered users and 37 guests
