Page 1 of 1
Posted: 13 Feb 2007, 10:50
by nay-seven
a way to delete last track added..?
maybe a way to confige usine ( in setup ) to stop audio engine when minimize..?
could be usefull to edit a sample in an other software
a way to name a patch in the grid window without to save it as a patch before..?
yet asked but when i close usine , could be cool to have a
" the current workspace has been modified
do you want to save changes , yes , no ,cancel... "
Posted: 13 Feb 2007, 16:26
by senso
thanks for feedbacks,
A lot of other stuffs like that: insert, delete, move...
I'm not sure I understand the reason?
Yes I'll see what I can do.
Dangerous? Actually you can rename the track.
If you insist!!!
Posted: 18 Feb 2007, 10:32
by nay-seven
thanks to listen senso..;-)
about stopping the audio engine , an other example : i record some tracks , and want to check the result in winamp , for that i've to go in the setup panel and stop the asio4all driver , if not winamp give me an error..same if i made a pause in my creation and go on website with music streaming ( myspace for example..)
if you insist..
don't want to bother you with that...;-)
but time to time i made a little change to a song , then phone or a visit , forget my changes and close usine without saving...i know i've a little HD for brain...
Posted: 18 Feb 2007, 11:34
by senso
It's not only 'stopping the audio engine', but close the driver, cleanup the memory, etc...
If you make sound design I suggest you to buy a 'multi client' sound card that allows the playing of multiple applications simultaneously.
Don't you think it's finally simpler?
Posted: 18 Feb 2007, 11:55
by nay-seven
strange cause i've a an edirol audio capture UA-20 as soundcard and i can run winamp +myspace+ soundforge...in the same time
so...
