I use a lot the new draw modules arrays , they are really cool.
I have many ideas where it would be cool to have a 'not draw nth connection' option, if that was somehow possible and
not too complex..
for example we could make 'arrays of faders' or "arrays of knobs" or "arrays of trajectories" to feedin Matrix cellz:
ie for a basic fader made of two points and their link.
for cell0
two points 0and1 would make the fader (via the connection in btwthem), then the connection between point 1 and 2 would not be
drawn, then point 2to3 would make the fader inside cell1, ect..
so in this exemple that would make "don't draw each 2", but we could imagine don't draw each 4 for ie create a movable
rectangle inside a cell, or each 8 for 8leds encoder inside a cell ect, (if ideally on top of that we could control conextions
colors via arrays) we could make matrix colored faders in cells, to get better overview of values.
think that would be really powerful and modular, basically making "arrays of bmp styles using n points" via script.
it's already possible but the fact all connextions are drawn make hard to read as a link will go from one cell to other,
or overall create "individuals" objects.
what do you think?
don't draw Nth conection
I'm more looking on a solution to draw segments (lines) on the draw panel. Then it will be possible to draw anything.
Users browsing this forum: No registered users and 59 guests
