On the sampler, with Overdub Mode, if Rec and Play is set to off, we can hear the audio input ...
I don't think that's a good idea because if we pass the audio input via another track ( thay call it rehearsal?) , we hear a chorus effect while overdubbing because the audio input is pass twice.
Another example : when we use direct monitoring with our sound cards, the same problem appear cause the sampler let pass the audio internaly.
Could you change this Oliver?
Thanks you.
Rec and Play pb.
I'll take a look, normally it shouldn't be a pb
Users browsing this forum: No registered users and 73 guests
