more comma text ins and outs
Unread post by woodslanding » 10 Mar 2009, 07:02
Especially out of the conductor!
(I think I asked for something similar before, but that was before (or before I knew about!) comma-text ins and outs. Just want a regular listbox to select conductor presets from the touchscreen.....)
Also preset list comma text out on VSTs, so when I add new presets I don't have to manually update the preset select list.
And also, still wanting list-based mapping of controllers to VST parameters, so I could wire something up like this:
VST------>parameter list comma-out------->parameterListbox comma-in (1...n)
:: populate many different list boxes with the parameter list for the vst
Knob/slider (1...n)---->parameterListbox (1...n)-------->VST parameter control input
:: send multiple parameter value changes to vst from different controllers
Still haven't found a great workaround for this. I can do it via MIDI, but this limits the size of the parameter list.....
And as always, apologies if this has been implemented in one of the updates and I missed it!!!
cheers!
-eric
Unread post by senso » 10 Mar 2009, 19:12
It's a good suggestion;
the strings management is rather new in Usine. I've just realize how powerful it can be in a modular context; (I program faster than my brain...)
Also I know that I have to rewrite the vst module to add several new functionalities like this one.
be patient.
Unread post by 23fx23 » 10 Mar 2009, 20:04
Ive been using comma text of list box to easy update display of fx names on my interface and that's great! as said for modular concept that rock.
Unread post by woodslanding » 11 Mar 2009, 19:30
Are we there yet, are we there yet, are we there yet???
Okay, I'll be patient.....
(twiddle,twiddle,twiddle)
cheers!
-e
Users browsing this forum: No registered users and 75 guests
