increase max ins and outs on script module???
Unread post by woodslanding » 18 Dec 2008, 00:21
There seems to be a maximum number of ins and outs allowed on a script object. How difficult is it to raise that?? I'd like to control the text to a grid of 64 (or more) buttons from a script, but the script craps out at 48 i/o's. I'd rather use array outs, but I don't see a text array output object.
-eric
Unread post by senso » 18 Dec 2008, 08:59
there is no limitation of the number of inlets/outlets in a script.
But depending on your screen resolution, you may have to scroll the module panel panel (yellow arrows) to show inlets at the end of the list.
Unread post by woodslanding » 18 Dec 2008, 19:34
so the module in the patchbay also has to scroll its connections??? That's strange behaviour, but okay, I see how it works.
Oh, okay, I clicked on the view box in the corner, and now I see all the connections.
Thanks!
-e
Users browsing this forum: No registered users and 80 guests
